80k engine maintenance
bart2181
birmingham england
Guys my winter hack 1100 is off the road for some summer maintenance.is there anything I should be looking at changing inside the casings.tensioners etc.the bike runs fine apart from a little miss fire,stumble throughout the whole rev range but only when hot.cheers peeps
Service
Just carry out the normal service routine as always at the specified intervals. As long as there are no problems why go looking for them.
Some of these bikes cover mega miles without a single problem others are not so lucky, sort the problems if they present.
Only exception would be the cam chain tensioner upgrade if you have not already done it and if after servicing the bike if you still have the hot running issue have a look at the coils.
+1 for Dizzy.
117,500 miles on mine and apart from servicing I haven't touched the engine.
