911 Fault codes ?
Santa-2512
Omnipotent one
North Pole
OK, did my GS911 scan yesterday,
as i expected the ABS was running fault codes..
25074 Internal control module error - Analog value of front control pressure sensor
The fault is currently present.
25193 Brake fluid level to low
25153 Internal control module error - Communication timeout between main and control processors
The fault is not present now.
24957 Internal control module error - analog value of rear control pressure sensor
24950 ABS motor front, defective
Expected ,given it's had surgery lol
Although i have an idea how to fix the lights issue, without taping them up
The others were
ZFE - Basic
41720 Rear light open-circuit (or Radio Power supply for R900RT (K26) and rear fog lamp for R900RT ECE EU-3 60kW (K26SF)
41704 KL30 (Battery positive) under voltage
Rear bulb blew last week, so again not unexpected
Battery low, - not sure i will monitor that one (new battery fitted)
Kombi
37641 Electrical System (KL30) under-voltage
Battery (again)
DWA (Alarm)
55623 CAN bus: No communication with any other control units
40316 Wake-up line
Not sure about either .. i know the alarm works, and i tripped it last week disconnecting the battery, so i know it works lol
Will clear them all tomorrow and see what returns ;)
When was the last time the bike was connected to a GS-911 as those faults might be years old.......
Unknown lol ,
As i say i know the ones its going to throw ABS etc, i will clear them and see what returns
The can bus wake up line one is interesting, not sure what that one is lol
mart
It looks like the battery was 'flat' so hopefully that explains all the unknown errors.
Unknown lol ,
mart
Please stop laughing out loud, it's not funny, i would cry out loud .:comfort . I hope they all clear.
A weak battery will throw out loads of fault codes. ABS needs a good battery so probably nothing to be too worried about.
Sent somehow.
Dont worry, it's me being Sarcastic, if you knew Delores, (the bike), you'd know it has history, hence my approach.
I was more surprised it only had what it had showing up :)
mart
