I've not found it running smoother but I consistently get more MPG with 98. 2-3mpg is normal. I can't really understand why but I'm not the only one who has noticed this. Any boffins out there care to take a stab at it?
Lighter wallet...![]()
Taint Octane it's RON, nothing to do with calorific value....
The most common type of octane rating worldwide is the Research Octane Number (RON). RON is determined by running the fuel in a test engine with a variable compression ratio under controlled conditions, and comparing the results with those for mixtures of iso-octane and n-heptane.
I think you need to read it again...
"RON" is anti detonation characteristics, again....Nothing to do with calorific value...
It's a comparison "number" . Count your fingers backwards on one hand, 10-9-8-7-6 & then add 5 from the other. Do you have 11 fingers ?
This refers only to "pump gas" mind you.. not aviation or red gas...
"A fuel with a higher octane rating can be run at a higher compression ratio without causing detonation. Compression is directly related to power (see engine tuning), so engines that require higher octane usually deliver more motive power. Engine power is a function of the fuel, as well as the engine design, and is related to octane rating of the fuel."
Please see my additional edit at the bottom....
Looks like I beat you to it....![]()
