ABS bleed nipple rubber thing
Jamieboy
Surrey
2000 1150gs abs.
Noticed with the tank off that one of the rubber caps on the large nipples atop the abs unit (non servo) has split. I assume this is bad as it will let air/water in???
Had a quick look on motorworks but couldn't find a replacement. Anyone know where to source one.
2000 1150gs abs.
Just get a blob of grease and put it over the nipple wont do any harm and itll stop the ingress of water n dirt etc ..thats what I do to brake caliper bleed nipples or if you can find the little breather cap that you get on new batteries ..
