Hi,
New here but couldn't find the exact symptoms I'm getting so thought I'd just ask
I have a 2006 R1200GSA - I have had it from new and has suffered a lack of use the last few years but now using it again more. Yesterday the brake failure lamp was flashing after a 20 mile ride - all was OK when I set off. I switched off ignition and started the bike again and all was OK a few yards after setting off as is normal. I left it for a while and next time I turned the ignition on the brake failure was flashing faster than usual. Without starting the engine pulling the front brake lever did nothing - i.e. no servo motor running as you usually get. Pressing rear brake and the servo motor started and didn't stop when releasing lever until ignition turned off. It seems to have settled into this state of affairs now - back brake causes servo to run continuously and front brake doesn't start servo. I have checked the levers (nothing fouling on handguard or anything) and I have checked the microswitches at the levers and both seem to be working cleanly. The battery is new and there are 12.7V across the terminals with ignition on. Any help appreciated on what to start checking next and where to look.
Thanks for any assistance given.
