I'm going to be installing an accessory fuse block and I'm wondering whether it's better to use the frame for grounding, local to wherever the electrical item is located or whether to run the ground back to a ground distribution block by the fuse block wired directly onto the battery negative.
Not sure if one is intrinsically better than the other and would appreciate some advice one way or the other.
Cheers,
Justin.
Cheers,
Justin.
