Power distribution block for hexhead?
Santa-2512
Omnipotent one
North Pole
I'm looking at some accesories for my hexhead
Sat nag & spots / driving lights .
I have a relay sitting on the headstock doing nothing,
so i guess that could be used for one item.
I'm know the Satnag needs one battery feed, and the spots/drivers another.
However i dont want to chav the battery with multiple connections .
Is there a power block of some sort availabe that can act as a main disribution point
away from the battery?
If you only need a power outlet (be it ignition switched or not) device the Fuzeblock has much to recommend. It's relatively inexpensive and allows multiple (6) outlets with varying amperages, up to a total max of 30.
I use mine to power an Airman pump, USB chargers, heated jacket/gloves, connect an Optimate 3 (as a feed) and still have two spare outlets.
