ACF-50 & Corrosion Block Grease
Annette
Lymington, Hampshire
We're pleased to let you all know that Rugged Roads is now an authorised distributor for ACF-50 products.
We now have in stock:
ACF-50 - 1 Quart Bottle With Refillable Pump Spray Bottle - £31.95
ACF-50 is one of the best inventions for protecting your bike against road salt and grime. There are many aerosol cans available but we use the refillable pump action spray bottle when treating our bikes. This means you can get the ACF-50 where you want it much more accurately and you aren't wasting any spraying it all over the place. We prefer ACF-50 because you don't need to reapply it over the winter months.
What's included in the price:
- 1 quart bottle of ACF-50 (that's just over a litre).
- A refillable pump action spray bottle.
- Full usage instructions.
Corrosion Block Grease - 45g Tube - £4.95
Corrosion Block Grease has the same corrosion protection properties as ACF-50 but in grease form. Can be used as an assembly grease (for example did you know that the copper in copper grease corrodes alloy?) so use this for such things as engine/transmission cases, caliper bolts, wheel bearings, wheel axle bolts (which always seem to corrode), battery terminals, side and centre stands, foot pegs, brake and clutch lever pivots, etc. etc.
Corrosion Block is an anti-corrosion compound developed exclusively to stop existing corrosion and prevent new. It is unique in that it is designed for use in electrics and electronics as well as metals and structures. This makes this product essential for your day-to-day routine maintenance and as long-term asset protection for your boat/equipment within the harsh marine environment.
Basically, these products are used to keep planes flying from aircraft carriers, so they've got to be good enough for our bikes :thumb2
