Hi
does your nav V unit occasionally have problems with acquiring gps signal? I have it quite regularly and the only fix for it is to enable gps simulator and switch it off few seconds later. That was the case on 2.70 and earlier versions. switching it off and on also helps but when nav is in cradle you can't do it as power button is not accessible.
