Advice on quieter helmet
Schuberth S1
Soory a few words deleted by mistake. The System 4 had the lowest impact score!Rated 8 out of 20. Schuberth 17.
Noisy helmets
Schuberth S1 is the quietest of all the lids I've tried, bar none.
It doesn't suit everyone but once you get used to it, fantastic!!!
Pat.
Re: Just to labour the point!
Skippy said:
The System 4 wasn't too clever! and a number of the flip fronts seem to be a bit of a risk.
Skippy.
Makes you wonder why Ride tested a helmet that is no longer in production and has been replaced by a newer version.
As for the test results, if you look purely at the impact, spike and strap test results, the System 4 scored 28/40, which is better than the Shoei Z-One, Roof Diversion and the Shark RSX, all of which scored higher marks overall as a result of the road testing. The system 4 only scored 3 points less than the Schuberth Concept and the X Lite 902 (both scored 31/40) and 2 less than the Dainese Casco Airstream (30/40) on these tests.
I would say the marks for "roadtesting" are more subjective and more open to variations than the actual safety tests that were carried out.
Bob
