Air box oil drain plug
The Moth
Member
GB
Just checking to see how much oil if any had found its way into the airbox of my 1150Gs, I understand the drain plug is a bayonet fitting and you turn it to release any oil out. The plug does not seem to want to come out it will become loose and let a few drips of oil out. Is this normal or should you be able to remove the plug completely.
