AIR PUMP COMPARISON
Hi Ian;
I put together the comparison chart below:
MICRO POR INFLATOR MINI PRO INFLATOR GT
Max Pressure 100PSI/6.84BAR 50PSI/3.5kg/cm²
Flow Rate 0.68cfm @ 0PSI/BAR 0.50cfm @0psi/14lpm@0psi
Weight 7oz/198g 18.2oz/516g
Air Outlet Zero Loss Inflation Connector Zero Loss Inflation Connector
Additional Fittings Sports Inflator Tips
Inflation Rate 3 minutes, 100/90-19 front tire, 0-36psi 7 minutes, 195/60/R15
5 minutes, 150/70-17 rear tire, 0-36psi
Run Duration 30 minutes/20 minutes cool down time 30 minutes/20 minutes cool down time
Max Current 4.5AMP @ 40psi 6amp
Voltage 12.0VDC - 14.8VDC 12VDC
Power 55W @ 40psi 72W
Motor Geared, fan cooled Geared, fan cooled
Noise 69 db 69 db
Dimensions 3.9”X3.62”X1.57”/99X93X40mm 4.75"x6"x2"/120x150x50mm
Power Cord Up to 9.8’/3.0m Up to 9.8’/3.0m
Air Hose Length 1.6’/500mm 3.25'/1.0m
Certifications CE, RoHS, ISO 9001 Factory CE, RoHS, TUV Factory
The MICRO POR INFLATOR is a newer product, about half the size, a third of the weight that can attain double the pressure. All this using less power (current) that allows it to be connected to BMW's motorcycle cigarrete lighter outlet allowing you to inflate your tires without triping the boke's protection circuit.
They both do the same, however the newer MICRO POR INFLATOR will do it quite more efficiently under all aspects,
Andre
