airhead wont start
SIM
YORKSHIRE
Got my gs out of garage tonight, left if ticking over, while sticking my lid on and shutting garage door, turned round to walk to bike and a pop and dust/smoke came out of head and then cut out.
Initially started again but on one cylinder, gave it a bit of gas and cut out again
Turns over but wont start, can anyone point me in the right direction
Will have a better look tomorrow, when I have a bit of time. but any tip would help
Simon
Simon
first simple one is petrol - is petrol low - flip in into Reserve - pull one pipe off to see if it is coming through
Won't start.
1;Check petrol is coming through.
2; Pull both spark plugs, ground the threads to the head, and see if you have sparks on BOTH sides.
Not starting can be: no fuel
Or no spark (at the correct timing)
So simple to diagnose,...... usually.
Good luck.
Bubb
Dropped valve, holed the piston, bent the conrod, damaged the big end, but spend a couple of thousand and it should be ok :D
A wee Tip i learned many moons ago , For a Combustion engine to start ,,, Its Needs ,,, Fuel , Spark , Air , take it in what ever order you choose .
