Grim Reaper
The most reasonable explanation for the 'excessive' rear pad wear is that (especially when using Dynamic mode as this seems to make more use of the rear brake for stability control) because the bike has linked brakes, and the rear brake is used whenever the front brake is applied, owners who have had bikes with non linked brakes in the past, who were unusually light on rear brake use (who isn't) are now seeing the sort of wear that they would see if they used the rear brakes more like they should have been.
If that makes sense?
Basically, if you had been using your brakes properly in the past, it wouldn't seem like they were wearing faster now.
simples
