Alternative single-output coil for post '81 airhead
John Roberts
North Wales
According to Motor Works and others they are no longer available new, is there an alternative available, please?
A Boyer Micropower system includes the coil, leads and caps, doesnt cost a lot more than some aftermarket coils and will probably work better than your 30 year old existing components.
Motorad electrik in the states have a new equivalent http://www.motoelekt.com/ignition.htm
Thanks, Rob, do you mean this:
Dual coils (pair) for all 1981 - 1995 with DUAL-PLUG IGNITION
BROWN coils have 1.5 ohms primary resistance,for 1981 through 1995 Airheads with EARLY, SMALLER ignition module and single plugs.
Damn, I was hoping to cut-and-paste the photo, it seems I can't, sorry.
Oops, just seen these are for twin-plugs. Curses.
Why not a pair of 6 volt Bosch blue coils? Very reliable
2 of my old airhead have a pair fitted for over 10 rears and still have one an 81 R100RS and the other an 85 R80RT
+1. These are probably the best replacement for the originals.
I just spoke to Motorworks and asked if they could suggest another coil, they said to go for the dual-output ELA44426 at £104.40. They said I would have to rig up some sort of bracket to mount it. Has anyone tried this solution, and if so, was mounting it much of a problem? Oh, and did it work OK? :)
PS ELA44426 mentioned above is Motorworks' own catalogue number, dunno if it's BMW's or anybody else's.
