The ignition light is a different wattage to the other instrument lights...
Also mine doesn't go out until around 1500 rpm and starts glowing again at around 900 rpm
The Alternator lamp is rated at 12 volts and 3 watts, part number 07-11-9-978-372.
more info from >>>>
http://bmwmotorcycletech.info/lamps.htm
Regarding the substitution of #193, #194, #168, #161, #158 used in the instruments:
These lamps are described officially as style T 3-1/4 and used at the tachometer, speedometer, turn signal indicator, GEN.
158 lamp = 2.80 watts, .20 ampere, rated 500 hours, a.c. (may be rated at 13v and .24 ampere), about the same light output as a
193 and 194
161 lamp = 2.66 watts, .19 ampere, rated 4000 hours, a.c. emergency use only for airheads.
168 lamp = 4.90 watts, .35 ampere, rated 1500 hours, a.c. This is a particularly good sub for the GEN lamp (/6 and later), as its characteristics
ever so slightly enhance the starting of charging.
193 lamp = 4.62 watts, .33 ampere, rated 5000 hours, a.c. (rated at 14 volts too).
194 lamp = 3.78 watts, .27 ampere, rated 1500 hours, a.c.; a bit less light than 168, 1500 hour life..
2825 lamp = This is a 5 watt Euro spec lamp, commonly also found in the U.S. .....12 volt rated, not 14 as above lamps; 0.4 ampere,
and brighter than 168 and 194, and very nice, if pricey, replacement for them. NOT super long life. This lamp develops too much heat,
IN MY ESTIMATION, for anything but the GEN lamp usage.
2821 lamp = 12 volt rated, not 14. 0.25 ampere, light output fair, only a slight bit more than the 194, and not super long life, but longer
than the bright 2825
ANY of these bulbs will work adequately, the #168 and 2825 being a slightly better choice for the GEN lamp, wherein you want charging
at the lowest rpm point where charging begins. Just a WEE tad of help though. You WILL gain more performance by using the latest 2.8
ohm rotor, if your rotor is an earlier version, and use the electronic regulator. For the GEN lamp, one should consider doing the resistor
modification which will help charging slightly, and eliminate a charging problem if the lamp burns out (rare as that is).
See the GEN LAMP Circuit modification on this website. Be cautious about the 2825 in other areas....due to the heat developed.
In general an E- prefix means European standards, which may or may not be better in some instances and is not overly important.
