Right Dennis,you're it
27th 10am Agerbavenny bus station.Be there or,err,be some where else
Thanks Fred. Yes, drop off system will be used. For any not familiar with the system, this is how it works. Understanding the system is important, as every rider needs to do their part to avoid anyone getting lost.
One rider, the leader, will stay at the front and is responsible for navigating the route. Another rider, tail end charlie, will stay at the back in last position. These are the only two riders who maintain their position in the group.
At every junction, the leader will point to where the rider immediately behind the leader should stop and mark the junction and indicate the route which the other members of the group should follow. All other riders pass the marker except the 'tail end charlie'. The marker then re-joins the group in front of 'tail end charlie'.
This approach involves all the group and the marker gets rotated from front to back and naturally moves up to the front again. The method works provided everyone makes clear, safe markings and doesn't forget they are in the No.2 position, when it is their turn to mark.
Nobody other than the sweeper is allowed to ride last for any reason whatever. If you want to leave the group you should pull in to the left in a safe, visible position and wave other riders past. When the sweeper arrives he will stop and you can then inform him/her that you are leaving the group.
This system means that nobody is under any pressure to try to keep up as they know the route will be marked. Tail-end Charlie will be identified by a yellow "Beaky" bib.
At the risk of being really boring I will run through it at Abergavenny for any riders still in doubt![]()
And if I'm tail end charlie again,I'm not wearing a feckin bib of any kind.So there
Yesterday 19:21
