Another failure
Spout
Stockport
I can’t sort this one out, anyone else had the problem?
I’ve only recently replaced it, so it’s fairly new, but it’s started to fail again. Turning it through 90 degrees doesn’t seem to do anything, and I’ve even tried blowing through it. I can’t see any signs of corrosion, and everything lines up.
I’m going to try swapping it for the one on the LHS and see what happens.
Any ideas, cos it’s got me confused?
So I'll start.
Is it animal, mineral or vegetable.
I can’t sort this one out, anyone else had the problem?..............
Ah, that's where you made your mistake. :blast Maybe you should have put it on upside down, not turned it through 90 deg. :nenau
Don't whatever you do try a LHS one. :eek:
But then, I've not the slightest idea what you're on about. :blast
It's got you confused.
how the feck do you think we feel. :comfort
try sucking it through rather than blowing ;)
Is it male or female?
Males are usually blue, females pink.
Males are better straight up but females are often found horizontal and so turning yours through ninety degrees might prove a little advanced depending on the age:rob.
I don't see how swapping from one side to the other would help, but if that's what floats your boat.....:aidan
What about a used one? Could be cheaper.
i think you are all wrong if it wont turn through 90deg heat it up and belt it with a big feck off ammer
The 2 little arrows on the back need to be lined up
If you get them slightly out the grommet will kink and eventually it will fail
a smear of oil of ulay is really helpfull
worked for me
The down draft biflicator and the fufu valve should be connected with a giggling pin or it's never going to work!!!
But seriously I think we've scared him off.....:rob
I thought it was a problem with his cammets. If he has a 1200 then they're hype wangled cammets and need careful handling. Too much rotation will cause them to vibrate and that could damage the interlocking dreel sprale. :rob
