Another new to the stable...
Dragon Master
Kendal, England
Right, as I just posted in the 'neutral light' thread, a friend has just bought herself an '07 X Country. Seems a nice little 'bike, she likes it, but as an 1100GS rider, I know sod all about these smaller bikes. Owt I/we need to be looking out for?
She's going to work in her car tonight, so I'm going to get my first play on it. :bounce1:bounce1
Great bikes' indeed ... a lot on here have them as their second errr mmm I mean first 'bike :D
Nothing particular, maybe wheel and steering head bearings ... otherwise ride and enjoy.. If it looks right and came from a good home it will be right. Have a look at Ash's 'Happiness is' thread :thumb2
Not bad.. 138 views, and just one reply. Chatty lot, aren't you? :D
Cheers for that Mickey. The reason I ask is that at the moment, for Linda any 'maintanence' beyond putting petrol in is a foreign language. I'm going to try to change that, but in order to do so I need to find out about the bike myself.
So far I've come across the things about the gear lever (fit F650 item), the fun with the lack of bush in the clutch cover (get later cover, or have a bush fitted), and the alloy rear sub-frame. I could get that reniforced, but as Linda's insurance doesn't allow pillions yet, it should be OK for a while.
One curiosity I noticed today during a closer inspection, it appears to be half an ABS model. 'Half', because the light is there on the dash, and seems to work in that it goes out a few seconds after ignition is switched on, presumably after doing a diagnostic check.
The switch is there on the right-hand cluster, and the rotor and sensor are present on the rear wheel. But nowt on the front wheel... :nenau
Anybody got any ideas, or better still photos/diagrams of the mounting point for the sensor at the front? I've got an idea it might have been removed for some reason, (the last owner lowered the rear brake pedal out of reach 'cos he never used the rear brake).I've had a look at the hand book, but the photos are a bit vague, and I could do with finding the mounting point for the sensor if there is one. Photos of the sensor on Google suggest it might just fit on to a bolt that's there anyway.
It still seems to ride OK (not tried it myself yet), but if it's an ABS bike, all the ABS gubbins should be present.
Also, any idea where I/we could get a new baffle for the (BMW) Akraprovic exhaust? It was there when she picked it up on Thursday, but not on Friday morning in her garage. It's not too bad without, except that it tells the world when she's accelerating hard. :D:D
Two other questions: Oil, 10/40 semi-synth OK in this engine? And is the coolant a standard anti-freeze mix?
Cheers,
Dave.
The pick up and rotor on the rear wheel could be the speedo sensor?
I think its 15/40 oil, but not 100% sure.
10/40 is what the manual recommends Iirc, semi synthetic should be fine, but there have been clutch issues reported when using full synthetic.
Just check the clutch cover and it should be fine for road work.
Good luck with it!
