German Behr spoked wheels on 1100/1150/early aircooled 1200's seem to be much stronger
Discuss
Discuss
So do I.
I keep saying it because BMW spoked wheels over the past 3 years have had catastrophic failures and BMW won't accept liability.
So.... if you like your bike and do a lot of road miles, switch wheel types.
It only cost me £450 to do it. The alloy wheel-sets come up on ebay often. It's not a huge expense, especially for extra piece of mind.
I think they look great![]()
You pay £18,000 or so on a motorbike and then have to go to ebay and buy a set of wheels so as to be able to use it. Brilliant value.
(hex head though ,,last of the "proper" bikes
)Yeah but people want the adventure look.
You don’t get that with cast wheels, apparently.![]()
Crazy, isn’t it. Quite why you can’t spec alloy wheels from the factory is a mystery, especially when most bikes are built to order.
If this is true that's shameful, the point is if the customer is getting it fixed under warranty he is happy and it's getting swept under the carpet , BMW will know how many wheels they are selling.Given the experience of the wheel builder is in the millions across multi 2 wheel platforms and it seems to only affect this particular wheel set it has to be more than just poor assembly given the number of wheels with loose spokes and the fact they continue to come loose on new bikes after the issue is known to bmw.
Last time mine was in for a service I heard them telling a 1250 owner at his first service that he had to have a loaner whilst they sourced a new wheel due to loose spokes. Something like the spokes are stretching or the spoke heads are regressing into the rim etc.
They do look more bespoke.Spoke wheels look better.
My Exclusive came with Alloys, but ive seen other identical bikes with spoked wheels. I dont know how you pick one or the other, i certainly was never asked what i wanted, the bike just came with alloys.
No option if you choose the Rallye version though - spokes only.
I have a life time of metal bashing , repairing etc . Alloy ----steel etc etc .
If there was something wrong with the caliper mounting ie just not strong enough , logic would dictate that it would fail when under load . The main load would be under very hard / harsh braking , none of the failures of the rear wheel that I have read about have been during the said hard breaking .
Something suspect about the wheel design/ loading pattern .
Said overloading in progress(hex head though ,,last of the "proper" bikes
You can ask - they will swap them FOC for you - they keep the spoke wheels and sell for a profit! My mate has a Rallye with alloys
R100gs which used tubeless rims has grub screws as did the oil head as did the hexhead as does the LC.The fact the spokes are now locked by a grub screw tells you that the angle of the spoke is an issue maintaining tension wise.
Only later LC's therefore the issue is not the concept it is the choice of materials or build quality or both.
Incidentally my 1200 lc gsa has done 40k with substantial off-road use... no issues with loose spokes.....
