Any mechanics in the Manchester area, pretty please
jojitsu
Manchester
Hi all. I recently picked up a K75S with sidecar to take out my elderly dad, as his biking says ate unfortunately now over.
I have just gone you take it out of for a spin and it's pissing oil out. I have just asked on a Facebook groups and it's the clutch Boot cup/rubber boot for clutch pushrod.
Are there any mechanics in the Manchester/Bury area that have experience with these?
Please help! 😭
And here is the bike
Mobile chap will come to you
Do something sooner, rather than later! As the fluid is heading up the pushrod to the clutch assembly (if it does not have the felt washer)!!!
Before I did anything Else I would open the gearbox filler plug and verify the levels?? There is a Small dipstick in the tool kit that it should be filled to not the full depth (I have seen a couple!!!)
Edit Early ones had the Shock spanner with the line on it and the later ones got the small L shaped dipstick basically max is 115mm below the top of the fill port
Fill it back up to the dipstick level with Heavier weight oil 85W140 GL5 drop the boot off (Carefull! it is likely half full in there!) and scoosh out that area with brake cleaner as that looks like pretty thin pish leaking out? Maybe even a low viscosity fully synth!!
#NotAnOilWar
but I have seen many people using fully synth in older bikes with older seals and developing leaks a thousand miles later! When asked I just tell them drain down the oil overnight and refill with the appropriate mineral of the correct viscosity and volume, It appears that that the fully synth can find it way past older seals All of them sealed up with the original oils again People are far too precious of the "oil" The appropriate volume of the correct grade and monitored and topped up, is all that it needs!! Except BMW dry plate transmissions It HAS to be GL5 spec Not a hybrid GL4/5
Anyway if the above does not fix it? Its time consuming but can be sorted fairly easily, At least with the Chair you can jack it up and get an axle stand or two under it,
Drain gearbox, Remove the rear wheel / brake / swingarm and stuff and that that will let you have a clear look/ work at it (Just hang the calliper up off the rear rails don;t disconnect the brake line and be careful with the speed sensor wiring just unplug and snip the thousand cable ties )
Important! Order a Boot and a Clamp The one you have will likely be like jelly at this stage and likely the clamp will be seized despite all the gear oil
Order a seal as well Shaft seal 9X15X4
and a can of brake cleaner to get that all washed down
Now I can't remember exactly the rear of an older K gearbox, but Small drill Smaller self tappers Drill closer to outer diameter spray off debris and screw in self tappers and pull / lever and hopefully the seal will pop out for you ! I had bother on a very corroded one (the boot spilt and let is salt and schite) and had to use an old pair of Mercedes dash pulling tools
Clean it all out well
I got a nylon bush made that fits in the orifice and allows me to tap the seal in to the correct depth*** keeping it half square you might manage with a socket that is as close as possible to the outer seal diameter without being bigger as it will bind and mess you up! ***check depth before removing
Reassemble Cleaning and Lubricating as you go If you want to do the output seal and swingarm gaiter this is the time!
Like I say its okay but time consuming and the seal is fiddly Just do your best not to damage the sealing surface on the shaft where the seal runs !!
#NotAnOilWar
Like I say it’s okay but time consuming and the seal is fiddly Just do your best not to damage the sealing surface on the shaft where the seal runs !!
Really nicely explained, tip of the hat to you sir
#NotAnOilWar
Wow, just seen this! Amazing advice and knowledge, thanks so much! Outside my skill set that, I've contacted motorevive, and hopefully I can get him up outside his usual patch. He reckons it's a quick 10 minute job.. 😬
You could at least check the Oil level LOL
The horizontal Plug above and in front of the swingarm
if its up near the top that is your problem :D
Should be about 4 inches down
Yes, I'll definitely do that. Just gotta get it up my steep driveway and find a level area. Cheers 😂
I rode it home to Bury, Lancashire from Peterborough via the Peak District when I bought it recently. Didn't seem to have any oil discharge at that point..
I live in Milnrow not that far from you, and have to say the lack of decent bike mechanics is surprising.
Hope you get it sorted, great looking bike btw 👍
