Anyone know how to wire up a BMW Switch?
MikeO
Dereham, Norfolk, today...
Fitting some spotlamps & foglamps on a mate's GS. I'm using the Adv foglamp switch (the one that is mounted in the centre of the bar mounts) to isolate the fogs from dipped beam when necessary.
It's a straightforward BMW illuminated rocker switch, which has 3 wires coming off it. They are:
Post 1 - Brown
Post 2 - Yellow & Purple
Post 3 - Blue & White
Can anyone tell me which supplies power to the light in the switch and which two are the switched wires?
Mike:)
Mike,
I don't have a diagram, but you should be able to find out by trial and error...
1) I'm almost certain that brown is ground.
2) Connect Yellow & Purple to +12V and test te switch to see whether the light in the switch goes on/off
If so, the other one is the swithed wire.
If not, swap Yellow/Purple and Blue/White and test again.
That should do the trick. I don't think (don't shoot me if I'm wrong) you risk anything by trying this.
Cheers,
Michel
Thanks Michel (& Roger, who PMed me). For those who may need the information in future, it's the Blue & White wire, attached to Post 3, which operates the indicator lamp.
Mike:)
