Are adjustments for altitude really going to be necessary?
I just want to get the Air/Fuel ratio sorted.
The AF ratio will need to adjust for atmos pressure to be at its best so a device that fits to the bike and sets the AF ratio at a specified atmospheric pressure, say sea level, and remains set at that will not adjust for say the high alps. Or indeed differing pressures due to weather but this is a digression.
Temperature also plays a role but again not sure what or how ( it was a long time ago when i went to school) I do know that cold and damp air gives a bigger bang and presumably requires less fuel at the same time.
A re map that incorporates the use of the bikes oxygen sensors etc etc and can adjust accordingly and so giving the desired optimum fueling all the time has to be a better option
That is true but the Motronic's have adaptive fuelling, by monitoring the products of combustion fuelling can be corrected for altitude, however it cant correct for the fundamental fact there is less oxygen, it can only attempt to maintain an AFR, so power will still be lost but in a euro compliant way.
Temperature is inversely proportional to density, a cylinder can only ingest a certain volume, cold air is is more dense therefore contains more oxygen for same volume. Under Wide Open Throttle more oxygen = more power
Indeed, looping out the O2 sensor removes the ability of the ECU to adapt to fuelling changes, which includes going onto the continent and using shite fuel, best left in IMHO.
Bloody hello was i right !
I should damn well hope something stuck....this subject matter has been done to death between hill-maps and XIED's
P.S. how's your coffee addiction?
Fuel injection? Only for for sensible people!![]()
Before I go to Hilltop again, I'm wondering if a power commander would be a better option this time round?
I don't have any first hand experience with a PCV, so is it just plug and play, or will it still need to go on a dyno?
Any advice/ info would be helpful (obviously not from Engineer).
I had a Tiger 955 with a dodgy air pressure sensor in the ECU. That was not fun at 2400 metres above sea level in the Alps.
That reminds of my first trip to the Alps many years ago on my CX500 - I thought the bike seemed down on power and was developing a fault until I realised that it was the altitude that was affecting the engine.![]()
as a general rule yes, if you don't have 02 feedback from a lambda or mass airflow meter as ever context is everything.You need a suitable map to actually - shovel that fuel in.
