MrkMrk11
£115 posted UK Mainland
As new Aoocci C9 Max. (literally used once for 2 hours)
Top of the range and brilliant quality - crystal clear 6" screen.
Twin 1080p camera's and unused Tyre Pressure Monitors, for Apple Carplay and Android Auto - (Android Requires 5G bluetooth and wifi).
I didn't use the TPMS as I am happy with the BMW OEM system.
Purchased and fitted in the winter, and now due to the nice weather finally used for 1 day, and it works perfectly but is just not right for me.
Comes with everything in the box that came from Aoocci and I will supply 2 new 3m sticky pads as I had the camera's stuck on.
Really simple to fit - Red goes to power, Yellow to switched live, Black to earth. On the BMW GS I just joined the Yellow and Red together to go to the SAT NAV prep live using a cheap adapter from eBay or Nippy Normans, as this comes on with the ignition switch anyway. I also tested that you could use something like a "Healtech Thunderbox" - join red and yellow together and put in the positive side and run the black to the neg. Of course if you have a hex ezcan or similar you can use that. On any other bike you need a switched live for the Yellow but there are plenty of You Tube videos if in doubt or feel free to ask me and I will help if I can.
The biggest problem is running the cables around and I must have re-routed them 3 or 4 times before I was happy - there are so many panels on a GS
