Bones
Had a problem with a weak battery last week so decided to run it flat (ignition on, engine off, lights on) in the hope that my optimate might 'fix' the battery to last a few more weeks. It didn't work! So in went a new Yausa battery. Instead of the motor bursting into life when the start button pressed I am just getting a loud 'click/pop' noise coming from under the seat hump. A closer look suggest that the click/pop is coming from two sources, a relay behind the 'box of chips/ecu' and a finned 'thing' next to the 'box of chips/ecu' on the right/offside.
Opinions amongst my mates include faulty new battery (but it wont jump start either
), starter motor solenoid and jammed starter motor.
BTW it's a 2001 RSVR.
Any advice gratefully received. Breakdown recovery will be called soon.
), starter motor solenoid and jammed starter motor.BTW it's a 2001 RSVR.
,but i must say all in all i think i have made the right descision in going for the aprilia i spent eight hours on it last sunday and i was smiling all day
