1643fuffy
Hi first post please be kind. I have a r75/7 and when I try to start said beast, the starter motor engages for a second then drops out. if I press button again nothing. after repeated presses the same happens, starter motor engages for a second or two then drops out failing to start. I have fitted a new starter motor. I have ordered a new starter relay. Is it the relay, wiring, kill switch or something else? The bike has not been started for 20 years. With a squirt of starter fluid it ran when kicked over so it will some more when I can sort the starter issue. Thank you for any suggestions.
