Arai helmet question.
hugh jarrs
Minnigaff
I have an Arai CT-RAM and would like to try it without the peak. Are there side pods from another Arai open face that will fit for me to do this ?? :beerjug:
I can't help you im afraid but I am interested in this thread as I fancy a ct-ram or ct-f.
Are you wanting to change cause the visor catches the wind?
Both my Tour-X's came with spare pods in the box, so it could be used without the peak. If yours didn't, Arai should be able to supply some as their blurb says it can be used with or without.............
The CT-Ram can be used in any combination of peak and shield
Unless you just remove the peak and use the side pods to anchor the visor?
Failing that, ask them
The x-tend looks to be the same she'll and helmet but without the peak - I suspect the side pods for it would allow you to run it without the peak.
