monster-mash
Ok Guys, I am rebuilding the carbs on my 1st BMW G/S as part of the rebuild and need a little advice. Both carbs are Bing 32mm the numbers on the carbs are nearside 64/32/305 with the number 7/2 and a floating 6 or 9 on the other side of the carb, the off side is 64/32/306 with the number 9/2 again 6 or 9 on other side of the carb. The only other difference other than a no so polished diaphragm cover is said cover has Bing embossed onto the surface where other cover has nothing.
Is this normal or should both numbers match? Should i be bothered in any way?
I am rebuilding them at the moment using seals and gasket kit also replaced both needle nozzles as the old were pitted, i dont know how it ran before as all i do know is its been sat doing nothing for the best part of 20 years.
