DerekP
I fitted one of these and have the problem below.
http://www.nippynormans.com/products/autoswitch/item/autoswitch-as7-version-aut-as7
To: Nippy Normans
Happy New year! Have just fitted an AS7 auto switch to my 2005 R1200GS to run the Wunderlich flooter lights which I bought just before Xmas. Tapped and soldered into the Canbus system under the tank, switched positive (red and green) and the indicator cancellation wire (blue and white). Lights running off the battery via the relay and all working as advertised. Lights even switch off on their own after the bike is turned off. So far so good. The problem: after 10-15 minutes the AS7 goes dead and the lights switch off. The AS7 indicator light stays off and no amount of fiddling will get the flooters on again. If I turn the bike off and then on again, everything resets normally. Not sure what is going on. Does the switched wire (red/green) turn off if the Canbus perceives there to be too little current and so the AS7 then goes dead? Is the AS7 faulty? If I keep a small power drain on the switched positive will the system work? Many thanks, Derek
Reply
Derek
Never had a faulty one but a poor connection or ground has brought up the issue mentioned so please double check.
Regards
NN
I don't think there is a dodgy connection anywhere. The splices into the Canbus have been soldered as well as twisted round and the AS7 and the light earths are directly onto the battery.
Has anyone else had this problem and if so, what cured it?
Many thanks,
Derek
To: Nippy Normans
Reply
Derek
Regards
NN
Many thanks,
Derek
