Bendy toy
What a shame that DOT 5 fluid can't (they don't say why) be used in ABS systems. It does not absorb water.
https://en.wikipedia.org/wiki/DOT_5
Certainly on cars, there are dedicated bleed nipple spanners, they are just slightly smaller than the equivalent metric size...OK I have your address - I'll get them in the post tomorrow or Friday to you.
You might need to be a subscriber to PM.
Looks like I got lucky on my unit then![]()
Of the two units sent to me by DrFarkoff some were already broken on the R1150 unit and they are very stiff in the R1200 unit.
I used a ring spanner when undoing them - I figured an open ended spanner could be risky.
That's the nipples in the post now - was only a second class stamp so don't worry about payment - may be I'll take that sticky bun from you if I'm ever passing that way
Allow an extra day or two for the post to work it's way down from up here![]()
I too have had the servoectomy, and leds issue. Mine are currently blaked with a strip og duct tape at the top of each LED recess.The "brake failure" led recess was plugged with some high density foam, cut to shape and the red triangle recess had a red and an amber led. I cut a piece of high density foam to cover just the red one so I will still get the amber low fuel etc warning.
Pics to follow...
Thanks for the help and support and fingers crossed all will be well from now on!
John
