I've just been fitting headsest to helmets so I can wire an autocom pro 7 sport (7 pin) that i bought a long time ago.
I've got a box of bits and although I thinhk I've sorted most of it out, have got the two helmet sets working and talking to eachother, I'm puzzled about a couple of bits so here goes.....
I've got two parts that are very similar;
Both have twin 3.5 mm jack sockets on one end and a 6 inch (approx) fly lead ending in a stereo (3 pole) 3.5 mm jack plug on the other end
The lettering on the top indicates 'C' as the fly-lead end, and 'A' and 'B' for the sockets on the other end.
One though has a black base section, and the other is all red
Are these the same part? (would seem odd, as they both came in this second hand kit)
I believe the all-red one is a dual audio stereo isolator, so I can plug in two audio sources/an audio source and a 'phone, although I have seen something that looks identical described as a Garmin Zumo isolator...or is that the same
So the two questions on those two parts are...are they the same, and if not, what are they?
Secondly, I've got two rubber shrink wrapped PCB inline devices.....one has an 18 inch (appr) fly lead ending in a stereo 3.5 mm jack plug on one end, and a MONO 3.5mm jack plug on the 3 foot flying lead on the other end.......the shrink wrapped PCB is about 3 inches long all in.
The second unidentified shrink is mine and is from my old kit, is the same length, has a 3.5 mm stereo plug on a 6 inch fly lead one end and a PAIR of 3.5 mm jack sockets on the other.....I'm pretty sure this came with the newer second hand kit I bought, but if (as I suspect) it's the same but an older version of the red isoltor unit, I dont quite understand why he had 2 or 3 of them
If anyone can help identify these bits properly it'd be appreciated
( I can take pics if necessary, but hopefully the above should give enough info?)
And I do wish Autocom would put their part numbers on their kit, so we lesser mortals can work out what we've got
