dakarjim
hi
I've just picked up a set of lights to use on the Dak
they are 6.5cmx5cm
i've also ordered a relay, and am confident with wiring them up. I am probably going to mount them underneath the indicators on some sort of homemade brackety-type affair.
i do, however, have two questions to put to the collective wisdom of the forum:
1. do you think i should have them wired as switched spots, ie only on with the main beam; or wire them to be on both dip/main (and if this is the case, does it need a seperate on/off switch?)
2. is there any legal restrictions for the UK? i dont want something that needs removing come MOT time.
thanks in advance
Jim H
they are 6.5cmx5cm
thanks in advance
Jim H
