Pughy
Hi. My OS Auxiliary driving lamp on my 2103 GSA has packed up. I have put a new bulb in and checked the out put from the connector at 13.2 V with the engine running. Any thoughts?
check fuse![]()
U got HIDs if yes up the fuse I had this with mine
One on one off
Hi Gazza
That's brilliant thanks, I have checked the fuses and one is all misty and corroded so I will get to Halfords for a new onestill cant fathom out how it still gets feed to the socket !!
I'll let you know
Many Thanks
You need Amps as well as Volts to light up a halogen bulb - corroded fuse contacts may still allow the latter while preventing the flow of the former in the necessary quantities.
