Auxiliary socket fuse amp?
Ferretboy
Grimsby
Hi,
I've just added an auxiliary socket direct from the battery with a waterproof fuse, it obviously didn't come with a fuse but I'm unsure what size to fit? I'm thinking either. 2 or 3 amp, what would you recommend ?
Thanks,
Steve
Depends on what you intend plugging into the socket.Also what is the wire thickness ?
Its ohms law, I = P/V. Where I is current in amps, P is power in watts and V is volts. So for example suppose you want to power a 20 watt heated vest, then calculate 20 watts divided by 12 volts, which is just under 2. So choose a 2 amp fuse, or next higher.
I think i have 7,5A fuses in both bikes sockets. Heaviest load gives mini compressor wich i use few times per year.
Great tips thanks . I've used 17 amp cable , I won't be using anything heavier than a compresser and in reverse using it as an oximser charging input . So 7.5 amp as suggested ok you think ?
Now that's a good equation !
