B6 Flash on braking / engine braking and emergency braking.
dicktheleg
Pestie to the Nobility
Worcestershire, England
I’ve tried and failed miserably to configure flash on braking then show steady ( California settings) together with flash on emergency braking etc.
Bike is a 2010 GS 1200 with no abs but obviously the rear sensor is there for speedo etc.
Any ideas?
It’s in there Dick, in the settings. I think you have to uncheck one of the boxes. I managed it without a faff.
Good luck
Jim
Here you go Rich. Settings I’ve used to get what you’re after.
Hope this helps
Jim
I had mine setup for that, but changed it back to normal. It is extremely annoying for people behind especially in queuing traffic and is illegal in the UK, a kind police officer advised me!
It is ok to have flash on emergency braking or deceleration, but not flash every time.
I didn't research this point, just decided he was probably right and took the advice
I think that why you can set a speed cut off limit so it doesn’t flash under a certain speed.
California style just flashes on initial braking too, not constantly.
Well, I’ve got it working but no idea what I did!
I set the speed cut-off to zero and tested at a standstill and I get 3 flashes then solid on (California legal setting)
I’ve put the speed cut off at 15mph so it shouldn’t annoy folks in slow moving traffic.
I just need to check is till forks at speeds over that.
Thanks for your input lads.
Well done Rich
Hope you never have to rely on it.
I noticed the settings wording you have is different to what I have.
Keep safe
Jim
Cheers Jim
Me too 🤞🤞
I must say that folks do tend to keep a decent distance behind me as it’s bloody bright, even running 10% in daytime.
Keep safe yourself.
R
Hope this helps
Jim
Just had mine in for MOT. I have a soundbomb set to 2sec delay, and my B6 set to no flashing, 10% running light, 100% braking. The kind tester obviously got surprised by the soundbomb, and came up with these advisories on the B6:
“Rear Lower (additional position lamp is so bright that it may be mistaken for a brake lamp in operation) *DANGEROUS*”
“Rear Lower (additional position lamp operating as brake lamp is extremely bright when operating brakes. This is dazzling/blinding to driver behind) *DANGEROUS*”
It was a pass.
Do you reconfigure your setup for MOT purposes, or was my tester just having a bad Friday afternoon?
P.S. just checked last year’s certificate, which was a clean pass, from the same guy!!
My B6 and Lonerider spots + led replacement headlight went through the MOT in May with a pass and no advisory's
I think he was either being a bit of a *$¥*!!, or maybe had a supervisor watching. The same guy passed the exact same setup last year with no advisories.
Lesson learned - I’ll speak to the tester next year to save the grief.
I have my B6 set at 10% for the back light and it’s still rather bright. Even without a BMW rear light. (R1300 GS adv)
The B6 stop light is very bright at 100%.
Think 50% would be ok.
Indeed, my B6 is blinding, anything over 10% whites out the number plate lol
