baglux tank cover 1200GS
Not open for further replies.
The Moth
Member
GB
Just got one of these any tips or hints in fitting one
Andy M
Whe I put mine on, all I did was remove the side panels and lay the cover over the tank. I directed the ties towards the frame/headstock/beak framework and worked well. Fitted many baglux's over the years and they all look quite difficult the first time.
Hope this helps
warm it with a hot air dryer or in the sun if you need it more flexible.
choose a warm day, leave the cover in the sun to warm up, take the side panels off, take the front seat off.
put the cover in approx the right place and start threading the straps - be careful not to affest the steering with the front ones.
when all straps are attached start tightening them gradually in rotation - ensure that the filler hole stays in place.
Fianal tighten should be very tight.
Put side panels back on - if clips are in the way then tighten a bit more.
finally check it all in a few days as sometimes the vinyl stretches and you have to retighten the straps.
Loop the front straps to stop then being annoying - I would reccommend not cutting them as it is easier to reattach if they are full length.
One very worthwhile mod for me was fitting extension straps to the rear of the tank bag to make it sit a little further forward (to me all Baglux covers have the tank bag to far to the rear) and I could post some info/photos if anyone is interested:beerjug:
Thanks to all, fitted and looking good
Andy M
Baglux
Hi Andy,
did you buy the cover direct from baglux, if so do you have a phone number, ive got the code i want of the website but cant find an english phone number.
Lloyd
Hi Andy,
Lloyd
What colour do you need?
I have a Blue/greyish silver one not used any more.
baglux
Hi,
Just ordered a new Black R1200GS so it would have t be black, thanks for the offer tho.
LBL
