I've seen references here and there to having an engine 'balanced' and its not referring to carbs. Anyone here know what that entails and whether it does anything useful? Would you get a very smooth engine if it were 'balanced'?
Won't make a great deal of difference on a BMW horizontally opposed engine. Perfect Primary balance, Perfect secondary balance.
The main components are already balanced properly, but the rocking couple is a mess.
Look down on motorcycle from above.
Note that the cylinders are not in line.
Up to and including 1150s no compensation. 1200 on, a single balance shaft but 2 are needed to do the job properly.
The single shaft quarters the amplitude, but multiplies the frequency by 4.
What is a rocking couple?
To see it in action, take a push bike & turn it upside down.
Take off chain.
Crank is in perfect balance.
Give the crank a hard spin.
Bike just flew all over the place.
This is a rocking couple.
Myke
