I may struggle to describe this well - bear with me.
1975, 80k miles.
When running points the base plate was fully advanced and the view from the inspection window at 2800rpm was this:
I took the bike out for a run, 50 miles, no problem. Next day I covered 8 miles before it started missing, then cutting out entirely. The timing was out.
I took a punt on a Boyer Bransden module paired with the original coils and a new battery. But with the plate fully advanced (anticlockwise) the F mark is just north of the inspection window at 3500-4000rpm. There is still the double image appearing (letter F).
QUESTIONS
Does the split image in the video indicate chain or sprocket wear worth addressing at 80k?
With the Boyer, what would cause the stator to run out of adjustment before F is reached? Chain slack, cam-nose runout, something else?
Is elongating the points plate slots a reasonable fix?
Work so far:
1975, 80k miles.
QUESTIONS
Work so far:
- Stripped and rebuilt carbs (twice)
- New plugs
- Swapped leads and coils
- Set valve gaps
- New battery
