As per the title really, I am getting the slider tube bridge cleaned up and re-painted, and want to remove the ball joint, does anyone have any tips/tricks to help?
How did you hold the bridge down?a 1 meter long lever helped me remove it.
I have inserted 2 screws in opposite one to each other and held them into a vice.
like 2 and 7 o'clock.
it required 3 people to undo that f***ing screw...
I did not heat it or anything, and the threads were in perfect shape after the job was done.
the new ball joint had something on it's threads, green stuff like loctite?
Ideally you'll need heat to remove it:
http://www.loctite401.com/template/ying/pdf/docs/2701-EN.PDF
The green stuff will be the remains of loctite 2701 which is a super strong thread lock (the same stuff is specified for paralever pinions). Getting this stuff to release without heat is very difficult and in threads into alloy, you can actually strip the threads out of the alloy component before it releases. Loctite specify 250 C in order to dissasemble - in a real world situation it depends on how easily you can get heat onto the component without damaging adjacent stuff / paint finishes. When removing my paralever pinions, after faffing around with hot air guns and gas torches I settled on a 25w soldering iron with the bit removed - this fitted nicely into the hex socket on the pinion and allowed me to get it good and hot without worrying about burning the surrounding bits and pieces (I just left it in there until the pinion was 'licked finger' sizzling hot).
Like I said, I did not use heat and I have not destroyed the threads on the old joint nor the thing it screws in.
But it's best to check with the manual, and if there is mentioned to use heat, use it![]()
http://65.213.72.112/tds5/docs/2701-EN.PDF
This should get the Henkle website info on 2701 which informs that 250 C will aid disassembly.
Their is also a graph that shows that at 100c the product is at 50% of its nominal strenght, so the hotter, the easier...
