Bar riser/ pivet ??
Toy24
Leeds, England
HiFolks
Has anyone fitted these items on a LC . I am sort of happy with the standard set up , but i am toying with the idea of trying to improve my arm position just finding it a tad of an over reach but not really an issue.
:rob
A friend of mine fitted some recently and he is very happy with the results. He used to get a dull arm ache with the standard setup, but now cured.
I have a 13 GSW and have tried 3 different risers so far:
Rox 1 1/2" (37.5 mm) Fixed
Rox 2" (50 mm)Pivot
IliumWorks Bar Back Rise 1.3" (31.5 mm) / Back 1 1/2" (37.5 mm)
I am most satisfied with the IliumWorks Barback as it includes a brake banjo extension that stops the brake line pulling. Now that I have solved that problem I need to be careful not to strain the clutch cable and left switch bank wiring loom. I have already partially pulled out the connectors on the left switch bank causing intermittent switch operation.
I now have the bars tilted up more to resolve the cable issue and I am ok with the height and closer position of the bars. I am 6" with short legs long body and these fit me just right, good for standing up too. I also have the SW Motech pegs lowered 15 mm lower than stock.
6"? Really? You would fit in a shoe box...
Or is that length rather than height?
I was referring to my cock but I suppose that was an overshare.
