Hi,
I'd like to swap the handlebar on my R1150GSA for a non-BMW item.
I've got the switchgear off easily enough, but I can't use the standard BMW heated grips because of how the wires are routed to the ends of the handlebar. I've got a spare set of Oxford heated grips to use but the issue is the throttle tube/pulley looks to be all one part of the heated grip.
Does anyone know if the plastic throttle tube can be safely separated from the heated grip so that I could use it with the Oxford item?
Thanks.
Thanks.
