bash plate question
sycomoto
Shropshire england
Any ideas on where i can get a nice large bash plate for 101. the standard one is the same size as the sump and i've noticed a few of you guys are running a larger jobbie. I've seen TT do one but as id like to fit one before i die i'm not going to bother ordering one of theres.
You need a GS sump to mount the bashplate on. It's got 4 threaded holes for the bashplate to mount on. The Paralever PD plate is huge compared to the standard GS one. I'm not sure about availability though.
Of course, the bigger the bash plate, the more chance of putting unwanted loading on the sump.
Are there any sump guards that mount to the frame?
No probs
I've got a gs sump and it has the 4 holes for the sump plate, so its just getting the plate. I've spoken with motorworks and the PD one is no longer available, Any ideas.
I use a standard 100 road bike sump on mine...
Gives you more oil capacity
Better cooling without a bash plate robbing you of air flow
so you don't need a fragile oil cooler
Cheap as chips second hand :thumb2
Not indestructible but you do need to hit it hard to smash it as i discovered :thedummy
And i don't think a sump mouted bash plate would have saved me from this...I recon it would have just transfered the impact to the bolts and broke the sump by the bolt holes...Unless you rubber mouted the sump then you got no ground clearance..
I have replaced it with another road bike sump and will slow down a bit over 3 foot jumps :augie
mm. i got the larger pd one on my g/s
was an ebay one, comes with the four mounting bolts rubber mounted they are
Sump guard bolt (R80ST R80GS R100GS) | ENA15059 £5.44 (INC VAT)
have you tried bmw i thought they were still available.?
Sorebums experienced his guard pushing excess forces through a mounting hole :
