Battery disconnected over winter . Dato Tool Alarm
Geno
Northern Ireland
They bike needed new battery, she hasn’t moved so can I take out battery or must it stay connected because of alarm . Was using charger but still died while waiting at MOT centre . So increased tyre pressure, ACF50 ,
Anything else ,
Many Thanks. It’s been a long time but do check in now and then .
Just change it out Geno it should be fine
Watch out for the Cable on the right hand throttle body popping out when you lift the tank
You will know if it runs like a pig afterwards
Its about time you had that alarm out They are like the Servo ABS systems on the bikes its not If they fail it is When they fail
