Had a flick through previous threads re clock resetting, which mine does too. Checked all fuses which were fine. So I hooked up a voltmeter to see what was what...
Ignition off - 12.45v
On but not started - 11.8v
Turning over - 7.8v
Running - 14v
These readings (other than the running value) seem a little low to me? I've found the bike turns over sluggish first time, but is fine after a short ride...starting immediatly every time. I'm guessing this means the bike is charging properly but the battery isn't in it's prime?
I spoke to the dealer who confirmed that the previous owner changed the battery in October 2008. Like myself the prevıous owner used it as a second bike mainly using for long distance rides. The bike sits in the garage for a 3-4 days. Optimate says it's fine, but that's not to be trusted. Does all of the above mean the battery needs changing and/or something else?
Denny
Turning over - 7.8v
Running - 14v
Denny
