Guillom
hi there,
questions for the more technical minds here. Got this GS1150 a few weeks back, changed the battery today as it seemed weak and old. Plugged everything back in, went to start her up, started fine but then didn't run well at all and cut out. Tried a few times, same happens, it starts but just cuts out as i releas the throttle.
Now i forgot to turn the throttle 3 times with ignition on after connecting the new battery, so un-connected it, re-connect, did the 3 times thing, and started up, but same problem happens.
So now i'm just not sure what is happening, checked the throttle cable and seems in the right place.
Any suggestion??
going away to England and then France next Tuesday, didn't expect to have an issue like that just after changing a battery...
cheers
Any suggestion??
cheers
