First start of the day, almost 100% of the time gives an ABS fault. I can turn it off, within minutes, re start it, and then no fault.
The battery was a new Oddysey about July last year, but there was a wiring issue, in August, where it shorted under the clocks and melted an amount of it's wiring. This was sorted, but it seems to have this issue since. Battery charges at over 14 volts when running, and after a run the battery voltage is about 13.2.
I've not measured the voltage drop yet on starting, what would I expect to see ?
Also, is it possible that the wiring issue has "upset" the battery somehow and so it's not supplying enough "juice" on start up ?
I tried it with a small booster pack and there was no ABS on start up then.
I'm happy to buy another another battery if required, but don't really want to buy one then find I have the same issue.
(Should add it has a brand new Valeo starter fitted a month or so back)
