njbhorn
Basic advice appreciated.
Battery dead. Not used bike R1250RT 2019 for about 2/3 weeks (it is very cold nowádmittedly) Put it on Optimax 4 Charger via accessory connection overnight but LEDs 3 & 4 just flashing all the time. In the past there has been enough juice to light up dashboard this time absolutely nothing bike completly dead.
Question 1
Best place to buy a replacement battery in UK (London) and what model number is it?
(Appreciate I can remove battery to get info but if I can get battery first)
Question 2
Is it reasonable for a battery to be dead this easily after 2/3 years? I do have a DataTool Tracker fitted but can't believe that would be too much of a drain on the bike?
The bike is stored in an underground car park and there isn't the option to leave it permanently on trickle charge.
Question 3
In the past I had a GS1200 with a similar going flat issue and replaced the battery with a Gel version and it never gave a problem with charge again. Is this an option for the RT1250 and does it make sense?
Thanks in advance for any help.
Question 1
Question 2
Question 3
