BBS Chips
Adventure Boy
Romford Essex
Hi guys can anyone tell me exactly whet BHP increase fitting a chip will give there seems to be no stats anywhere that I can find I know that there is some fitted out there and wonder if it is worth fitting one what benifits can I expect on a twinspark Adventure, What is the average cost of the chip and where can I get one
Adventure Boy:confused:
Excuse me, I'm not english, so, could You please press the -comma- key sometimes? Even randomly would be fine.:D
I don't think that you should really expect any power increase simply by fitting a chip. The mapping only really alters ignition timing and fueling.
The OE chip gives pretty much optimised ignition timing anyway but the standard mixure may be a little lean to meet emission regs. By richening the mixture, you might release a small amount of power (say 1 bhp) but should improve 'drivability' ie pick-up.
If you fit other goodies like cams, cans and Y-pieces, a re-mappable chip might facilitate getting the best out of those items. But don't expect to have your bike doing 150mph. If you want 'fast', by a different bike!
Greg
Il mio serbatoio di combustibile è pieno delle anguille, la carne è caduto della mia oscillazione. Inoltre i bikers allineare dovrebbero mangiare il lardo di MOR.
I can do punctuation in Italian!!
You can take a shrape intake of breath instead of a comma in Eglish especially bad English
Roger
Roger
... e la mia tromba dell'orecchio è stata colpita da lampo!
:D
Greg
Using the babelfish translation website I get:
My fuel tank is full of the eels, the meat has fallen of my oscillation. Moreover the bikers to align they would have to eat the lardo of MOR.
And:
... and my bugle of the ear has been hit from lightning bolt!
What the f...?
Adam :D
:cockeye :confused:
- unleaded eels I suppose?...at least be so nice to don't even think to post a question on butterfly's balancing...
:D
BBP chip
Here is my experience w/ the BBP chip (note that their website shows the power / torque increase, although one never knows how reliable those might be).
I first installed a performance exhaust (Two Bros, eventually got rid of it, too loud). This was before the chip install. Immediately noticed bery strong midrange, easy wheelies just opening the throttle in first. Also notice popping from exhaust on deceleration. After adding the chip, the really strong midrange was leveled out some (not as easy to wheelie - note, I am not someone who wants to do wheelies, they just happened). Stronger top end, it really pulled better throughout the range, even though the midrange was not as strong without the chip. No more exhaust popping. Seemed to reduce or eliminate the surging, which for me was really most noticeable while using light throttle in lower gears. Bottom line, I doubt the chip added much power, and actually reduced the midrange w/ my particular exhaust, but it did pull strongly up to 8k RPM, where before the chip, I found myself shifting by 7k RPM because the bike seemed weak above that.
The BBP chip has three main programs that can be changed, plus some variations on these based on fuel quality.I found that I did not like the chip if everything was stock (stage 1). By putting a Y pipe and going to stage 2, it ran well and was generally smooth and strong to 8k. I just got a good deal on a Ztechnik exhaust system and installed it yesterday and set the chip for stage 3. Time will tell how well it works.
In the states, the BBP chip is fairly expensive, but is fairly programmable. RhineWest now carries a GS chip that has two programs and is less expensive.
Bottom line, you will not get a lot of HP for the money, but you will eliminate the popping w/ performance exhausts, and will get more useable top end from the engine.
Fuel consumption
I hate having to stop for fuel, so what does the chip do to consumption?
The teclusion gizmo only adds fuel so to my mind that can only increase consumption, does this chip also reduce fuel when required as well as adding?
Roger
