Belt not chain !
Buckingham
North Oxfordshire
Guys,
working on an F650CS, 2003, belt drive. How is the belt tension adjusted ?
Though it's already a low seat model, we need to lower it even more for a very short rider. I'm thinking this means longer links between the triangular pivot at the bottom of the shock and the swinging arm.
Anyone know where to get these please ?
How would I work out the increase in length of the links to give a 30mm lowering of the seat, except by trial and error - in my case no doubt it would be the latter :toungincheek
Could anyone on here make some to pattern ?
Cheers John
Do a search for Kouba Links,they do lowering links for the GS but I don't know if they fit the CS.
Tony
If it came out of the factory as a 'low seat' model, I think they achieved that by lowering the suspension. If that's so, you may struggle to lower it further.
Greg
hi John,
have you been playing with the belt:)
USA blackbelt gang has some good info
http://f650cs.wikidot.com/belt-adjustment
i think kouba link do lowering links for the cs,also there was someone on germany ebay offering a lowering link.
the front forks do not have much adjustment on them.
these bikes are low with the 17" wheels.
they can give them gs's a run for there money:thumb
