Remember, your going to drop voltage when going series thru the rotor., so the light won't be that bright if you send the current thru the rotor first. It should be dimmer somewhat ....
On the /5, the rotor circuit goes thru all sorts of things, which at the time I found very odd, because the rotor is in series. The other loads on the same circuit go to ground. This can be a little tricky ..... fortunately mine was open so it was very straightforward for me, no intermitent opens or shorts..
